I had this problem. Reach under the car and push/bang on the hood with a stick or something like that. If that doesnt work, the cable is probably broken. But you can reach the latch, just pull it open. If the cable works, Grease up the hook on the hood and the the latch mechanism when you get it open. I just put a little oil on mine and it worked fine. Grease sticks thou.
