Thread: Heater.
Old 04-27-2006, 05:23 PM   #15
Burn N' Up
Burn N' Up's Avatar
The low speed is the resistor pack someone mentioned earlier, check the valve that DDMCSE talked, the VSV on it is known to go out, constantly! You can check to see if this is the problem by manually opening it with the heater in the car set to hi and with the highest temp. Open the valve manually, if heat comes out, you found your problem.
