Dropping Oil Pan
Just got an oil analysis back that shows coolant and lead (102 ppm) in the oil.
I'm just finishing a BHG repair, so cooland was expected. How hard is it to remove the oil pan in place---IF I have to check/replace the bearings? Oil pressure was fine before, and no knocks.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
