Could be a bad combo swtich too. Check continuity on your combos. I'd explain exactly how but its too complicated to post here... so buy a manual, it'll have everything you need. Usually e-bay has the computer ones, i managed to snag a paperback =D. Also the blinker really might be the problem. It is the first relay above and to the right of all your fuses in the driver's kick. But battery voltage to it at 1 and 3, check continuity at 2 and 4. Also could be your integration realy #2 aka retractor motor module. If not then some wires metled...
