I used to drive an IS300, and I desperately wanted to boost it after riding in a monster turbo IS from Toyomoto. However, the AWD bug hit me, and I bought an Evo instead of a turbo kit for an IS. The entry kits start around $6-7,000. I've seen them go up to $30,000. Since the block is the same as the Supra, with the right mods installed properly, the IS300 can be turned into a real boosted terror. It will cost you though....
The block in the IS300, as with the old SC300 and old GS300, is the 2JZGE. It is the same block, but not the same engine. Meaning, the IS motor wasn't built from the factory to handle boost, there are a lot of turbo components on the 2JZGTE that are absent from the 2JZGE. That being said, turbo components from the Supra will not bolt directly on the IS300. The ECU has to be controlled/tuned/even bypassed in an IS300 to make it into a turbo car. Here are a few of the manufacturers of quality IS300 turbo kits listed in order that I would purchase from:
1.) Toyomoto, Inc. - Miami, FL -
http://www.toyomoto.com/
I rode in a 550 whp turbo IS300 from Toyomoto, and that thing was scary fast!
2.) Peter Farrell Supercars - Maryland - http://www.pfsupercars.com/
3.) Powerhouse Racing - Texas ?? -
http://www.powerhouseracing.com/files/index.php
4.) Swift Racing Technologies - Maryland - http://www.swiftracing.com/
