Thanks for the info. I will check out the cannister tomorrow and check for some lines that could be loose. With our cars, the evap. system takes away that pressure that builds up from the cap? Is that right?
When I drive for a bit and then fill up, there is a lot of pressure being released from the gas cap. Normal?
