Thread: IS300 vs MK4
Old 05-02-2006, 03:49 PM   #1
supramanocnsd
supramanocnsd is on a distinguished road
well this is a good post too.. your talking about the diference in the 2JZ-GE aqnd 2JZ-GTE .... the block is the same in the N/A Supra as the IS300.. but the tune and comp are different..it does not perform in the same way..
Originally Posted by pwpanas
Good post jdub24! I'd add that the n/a (normally aspirated) head is completely different, which is why the 2jz-ge engine doesn't handle boost as well. On the bottom end, the only things that are different are the oil squirters and the compression of the pistons.
supramanocnsd is offline   Reply With Quote
