Originally Posted by G-string
So maybe i just didnt read what you said correctly but youa re going to but a turbo on your n/a block ?
there are two pipes that conect to the block from the turbo one is the oil pipe and not sure the other but they conect directly to the block soooooo not sure how your gona go about doing that
You read correct. My friend has a plan for how to run the oil and water lines. I hope to have a detailed write up with pictures when I am finished.
