they also make such a thing that you can screw into your spark plug holes and the connect to a air compresser and with the radiator cap off you put pressure into the cylinder and if radiator fluid shoots out the radiator then you know there is a blow head gasket.
87 N/A with a new JDM 7mge.
Looking for a 7mgte
