Keeping the fuel system clean really helps
^^^ You need to pull the fuel pump. The filter/screen, is attached to the inlet side of pump. You must remove the gas tank to get at the pump. Its such a big job, that I would replace the pump while I was there.
My pump is original on my '89, and still working fine.
I recommend using an injector cleaner in the tank every 10 or so fill-ups. (6 months). Techron is one of the best YOU can buy (I get proffesional stuff for the shop). They sell it at walmart, and chevron gas stations. Its in the gas at chevron and texaco.
