There's an easy way to find out if your TPS is improperly adjusted; run diagnostics. Search the forum for diagnostic codes, and if your car is throwing the TPS code (code 51) then run a search for TPS adjustment. It's in the TSRM. There have been a lot of prior posts about TPS, just run a search.
