Old 05-13-2006, 12:28 PM   #3
TONY!
TONY!'s Avatar
TONY! is on a distinguished road
Originally Posted by Reeves
The Head
...My mechanic just told me that the machine shop says the head is no good. He says it has rust.. He says it can be repaired, but the guy at the machine shop has another one... I don't know jack squat, but rust on the head doesn't sound right.. What do you guys think of this explenation?...
I firmly believe that not every mechanic nor every machine shop is capable of working on our cars/motors, so I never have 100% faith in what one them would say.
I have those thoughts from my own experiences.
Rust on the head? It is made of aluminum.
So what is rusted on it?
The Turbo
Apparently the oil seals in the turbo are bad along with some bearings. ...
They told you that? Or did you find that out on your own.
To check for wear on the bearings, you just need to spin the compressor wheel of the turbo at different points to see if there is any binding/rubbing.
I once heard that if you see dampness on the turbo, that is a sign of a bad oil seal.
Do you know how to shim the wastegate? That adds some PSI to your boost level, but most will tell you to just get a manual boost controller, since they are cheap enough (something like 10 bucks?)
-------------> ITEMS THAT ARE STILL AVAILABLE FROM AN '88 PART OUT <-------------
_____|_____
_________________
/OO]====(W)====[OO\
[___________________]
[ [O] ///______\\\ [O]_]
____________________[||]______________[||]____________________
TONY! is offline   Reply With Quote
