Originally Posted by Kai
Grrr!! I just went out in the car park and found out that my car has been trashed by vandals - i have four flat tyres, the supra badge on the front has been pulled off and the antenna has been snapped off.
The tyres can be re-inflated and the badge isnt a major issue - some double sided tape will see to that, but the antenna is a loss. Can i get just the replacement telescopic thing, or do i have to have a whole new motorised unit? Cause i'm rapidly running out of funds
doesnt the antenna go all the way down in the car when you shut off the ingnition? so how could they have broken it off if the motor did work? just wondering?
tony! or anyone elese...what would you use to unscrew the bezel at the base of the antenna because i need to fix mine also.
