No the 1/4 pannel is not attatched to the frame. I just had to cut one off a donor car from the junk yard. What i did was cut out the pannel so the patch will be square (dont try and cut round) . Also make sure you have plenty of extra in all directions on the good patch. Then cut the hole in the car (make it smaller than the patch cuz you can always trim off what you dont need), then your ready for welding, grinding, and filling.
