Old 05-18-2006, 09:59 AM   #2
f00g00
Default Check the little piston
There is a little piston the is actuated by the cable for the door release that sometimes sticks. You can access it through a little panel in the right hand side of the hatch area plastic trim. Just open the panel stick your arm in there possibly lube it up through the front or back and exercise it till its free.
