Old 05-18-2006, 07:50 PM   #12
Supra2NR
Supra2NR's Avatar
Default i've done it
i moved the afm to the throttle body,
perks of the move
shorter tube, since i only used one 22 degree bend tube it looks like a short ram intake, so the lesser the air travels, the faster it will get to the engine, and its less likely to lose velocity
its close to the fan so cold ait is more likely to be sucked in by the filter, and it gets fanned when you drive, better performance with no cost, everybody likes that right?
theres more space in the spot where the old intake used to go , so more air inside the engine bay and more air to get sucked in by your intake.
and not like i thought b4 u dunt have to turn the afm upside down or anything the wiring reached just fine, all you have buy is the 22 degree bend tube from pepboys which costs about 9.99, and a few adapters,and clamps
one important thing is the 45 degree adapter that you are gonna use to connect the throttle body to the afm.
the post might seem a little disorganized , sorry for that but im jus happy that i did something good
hope this helps somebody
while youre doing the move i suggest that you clean the parts too especially the afm i got pics here and u can see the diffrence
ID:	242   Click image for larger version
ID:	243   Click image for larger version
