You said 'dealer' installed. Tell us more about that. Did it run after it was installed??
Yes. Then perhaps the rotor is loose. Remove the cap and check it and the rotor. Mine came loose once when one of the screws fell out, after it was replaced 3 months earlier. Started misfiring and running crappy.
I put a drop or locktite on each of the screws when I put a 'new' rotor on.
I 'strongly' recommend locktite on these 2 screws.
