Old 05-21-2006, 05:45 AM   #2
mrnickleye
mrnickleye's Avatar
Wink Check some of these
Swap the tires front to rear and see if that helps, or shifts the vibes to the front.
U-joints ??? Axle joints ?? Grab hold of the pinion and see if you can move it up/down at all to check the bearings. S/B no movement.
Driveshaft balance???
