Old 05-24-2006, 11:16 AM   #4
f00g00
Default Grinding?
Possibly your starter isn't mounted properly, check for security and if the bolts are tightened. Mine was ginding beforeand it was almost falling off. I had to use a broom stick (my hood holder) underneath the starter to align it to get it started just to get it home.
The starter wont cause the engine to die like that though. Suggest you check the idle adjustment, maybe its too low, maybe the AC compressor is loading too much, could be many things.
