Thread: new 2 MKIIIs
Old 03-14-2005, 11:17 PM   #5
the_fallen
the_fallen is on a distinguished road
the facelift rear lights are not quite a direct fit. you have to drill a few holes that are not currently there. and while you have it apart, make sure that you check everything to make sure that it's not leaking, and get either new seals for the lights, or stick them on using a water sealant, as mk3's have a tendancy to leak around the rear lights. also have to redrill mounting point sfor the rear wing as well, the only points that line up are the middle mounts, the edge ones are not in the right place. you also need to drill two holes from underneath to be able to get the nuts onto the very edge mounting points that go down through the lid of the boot. and the side pieces need new holes drilled. make sure you fit the centre piece first, then line up the side ones to match that, otherwise you get them catching.
as for the head gasket, if your replacing it anyway, and plan on big things, then get a MHG, but make sure that block and head are properly skimmed, as tolerances on MHG's are a lot less. if you're not really going to be going big, even including a t04e wheel upgrade on the ct26, then just go for a standard toyota HG, and ARP's. keep everything maintained, and this should be all you need.
the_fallen is offline   Reply With Quote
