Originally Posted by h8z2luze
Hello, I have a 89 Supra N/T. I got it from an auction. The guy said there was nothing wrong with it but there is. It misses really bad. When I pulled the plug wires off the valley where the plugs screw into the head was full of oil. I have never worked on one of there straight sixes before. What does this mean? I hear it could be a blown head gasket or a craked head. How mush is a rebuld kit for these? Thanks in advance.
Just damaged valve cover gaskets. Mine has the same problem. As for the missing, try changing the plugs while you're changing the gaskets. Worked for me! (Should be $20 for the gaskets, $15 for the plugs, just about) Note, a mechanic should be able to do this for $120, parts included.
