they'll do it for you...to find out where your leak(s) are-
-turn your car on with the A/C on running on high
-shut all your windows and make sure your t top is on and locked
-get out and shut the door with your A/C still running
-take a smoke machine or some kind of smoke and go around the door seals and t top with the smoke. where you see the smoke blowing (or being pushed) away from the car is where your leak is.
if you find a leak (where the smoke was pushed away ) you need to replace your seals.
any window place will order them for u
