re: "losing coolant"
Yeah, I went thru this problem and thoght the bottle leaked. But in reality it was the coolant system. You should check the whole system, hose connections, gaskets, water pump. You're losing coolant from somewhere. I think you would have a lot more probelms if it were a bhg. good luck, hope you find it.
Scruff
