Old 05-31-2006, 04:20 AM   #13
razerback121
razerback121 is on a distinguished road
Hah! i just did that 2 months ago, have all the parts it took! You in the bay? 1 crtitcal thing you need to to do is.......replace every hose you take off, it wont even cost that much, and it good you good piece of mind. I didnt do this and now, 2 months later i've replace about 6 coolant lines that have decided to leak or blow. *head is very very heavy*(theres also a coolant line right in the rear of the exhaust side, hard to spot specially if your eager to get it off). To loosen the timing belt, theres a pully below centered between the gears, 14mm will kill it nicely.
razerback121 is offline   Reply With Quote
