Thread: new 2 MKIIIs
Old 03-16-2005, 11:51 PM   #6
hangsupra
Originally posted by the_fallen@Mar 14 2005, 11:17 PM
the facelift rear lights are not quite a direct fit. you have to drill a few holes that are not currently there. and while you have it apart, make sure that you check everything to make sure that it's not leaking, and get either new seals for the lights, or stick them on using a water sealant, as mk3's have a tendancy to leak around the rear lights. also have to redrill mounting point sfor the rear wing as well, the only points that line up are the middle mounts, the edge ones are not in the right place. you also need to drill two holes from underneath to be able to get the nuts onto the very edge mounting points that go down through the lid of the boot. and the side pieces need new holes drilled. make sure you fit the centre piece first, then line up the side ones to match that, otherwise you get them catching.
well...pretty much he saids all...so i dont have to said the same thing over again...so hope that work for you...
