Old 05-31-2006, 12:27 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by hobbes
I have a 95 N/A Supra 5 speed. If you take out the A/C do you get a noticable hp gain?
Also, I need to replace my struts and figured I would get a new suspension. What are some good brands to look at?
Although I'm less familiar with na's (perhaps other member(s) can post here as well), I'd have to guess that you wouldn't gain much HP from removing the A/C versus simply turning it off. Most folks I know that completely remove the a/c do so for weight savings, and possibly to increase airflow to the radiator.
The Mkiv Supra doesn't have struts, it has a double-wishbone suspension with coilover shocks. A couple of good replacements for the oem shocks are Koni and KYB (AGX). If you want to go to a full coilover system, Teins are very popular.
Life begins at 30psi.
