well....sometime its not the fuse that cause the sunroofs tho...it can be a relay...to it..i not sure bout the mk3 but on the mk2 relay is on the back pssnger seat that were on the side of the panel tho....i have 2friends that having the same problem too...but one of my friend we rewired the + to the sunroof motor from the door switch... the other friend he rewired the + from any wired that when you turn the key ing. on and it have power......so yeah....n he rewired that + to the motor....from his mk2 n it work....if you cant find the relay or the fuse or the problem to that...i think rewired all the wired are expensice tho...i think you sure try to do what my friend does...it save you a buck or two....cause u can do it urself for less expensive...
