Rubber stops
Also check the little rubber stops on either side mounted towards the bottom of the hatch on the car. The screws seemed to be torqued down to 100 foot pounds. I stripped mine trying to take them out but if the rubber is worn as mine are they will let the hatchback wobble which could be causing the rattle.
