I got my air filter from Autozone, its just a filter so I really dont see the point in paying for K&N. I got the kind that has the inverse cone opening at the top cause I wanted to duct in fresh air from the front of the car.
Long story short I consider myself a master of low budget mods. for my outside air duct I used various pieces I found in junkyards from stock air intakes. The piece that "scoops" the air is off a late 80's ford Truck. Its flat and has a hole already in the flat end of it where it mounts on the Ford, so I was able to screw that underneath my front bumper (basically to the plastic cover that seals the right side under the headlight) then with some other pieces I found I connected that through the oval opening that the original air box gets air from.
I noticed a difference in throttle responce and can hear my filter sucking when I thump the throttle...Im quite pleased with it.
____________
