Old 06-03-2006, 12:37 PM   #21
f00g00
Default My botch job
I tried the pipe idea and scrapped it the same day because the pipe was so hot and I couldn't find a heat blanket anywhere so this is still a work in progress for me.
My box is sheet aluminum cut and bent to shape, held together with pop rivets and covered with leftover fiberglass insulation pieces from a building under constuction that they used to insulate the CAC.
I still have to either cover the top or change the rubber up top to seal with the hood closed.
kind of a hack job first effort.
Jeez guess I need to clean the engine bay up some.
ID:	266   Click image for larger version
