Originally posted by suprra_girl@Feb 6 2005, 10:31 PM
the cams should be aligned with the marks on the backing plate behind the cam pulleys... you should see two lines and a dot on the cam pulley... align the dot with the small line
i would suggest getting someone to do your belt for you that has experience... if you get the belt out too far you can hit valves
well....like supra girl said....n the best thing for you to do is taking to the shop doing for u so that will be better of all....so yeah...hope that work for you... n have a nice one....
