Originally Posted by SupraMan1784
the 2jz motor is the most tunable engine in the world...its one of the most durable engines on stock internals...the other being the rb motor from nissan, there arent that many problems from the motor from teh factory...i think it was basically perfect....as for the avg mpg it changes...the more you mod the car..the less you getm which is the same for any car you mod, as for octane...usually premium is good enough but if i had one i would put supreme all the time....but then again as you mod the car more and more you will need a higher octane...just like any other car
I agree generally ... the more you mod the car, the more boost you typically want to run ... and for more boost you need more octane (or it'll detonate, which will wreck
any engine including the 'mighty' 2jz-gte).
