the turbo pressure signal = you have a boost leak which is causing the bog
also you will more than likely find that the wire has broken off the knock sensor plug or has a short circuit, or is not plugged in at all
there are two knock sensors on the intake side of the block about #2 cyl & #5 cyl
pull the plugs off and inspect them
good luck
