Old 03-19-2005, 07:47 AM   #3
hangsupra
well...iono about the mk3 but the mk2....some time its the gas filter on the block too...cause its dirty inside the filter....so it block the fuel...to send less gas....n also sometime it can be the gas pump like supra girl saids too...but i not so sure...bout that...but well....sometime....it can be your fuel injecter too....iono bout mk3 but in our mk2....it does that...how do you know its the injecter...well...when the motor is operate...does your engine sounds smooth or it sounds like it didnt burn well/enough gas....if it sounds good/smooth then its good its not the injecter...but it sounds like not burning enough of gas or when you accelerated n it keep having that one lagging problem like your engine almost die...like the engine stop n its on stop n on....like u were out of gas or somethings wrong with it...if so than its your injecter....so yeah...hope that give you idea what is it...
