Old 06-08-2006, 08:08 AM   #1
sd88supra
sd88supra is on a distinguished road
Default 86.5 and 87 symptoms
theres some wierd symptoms that i cant quite figure out. on the 86.5: when i go 3000+ RPM or about 35+mph i hear a squeaky rattling noise. i havent found anything in the repair manual with similar symptoms, so i have no idea what it is. at first i thought it had something to do with the front left wheel but i also notice that the spedometer needle bounces up and down when it does that squeaky rattling noise.
on the 87: when the car has been sitting for about ah half hour or more, when i take off i hear a squeaky noise in a sort of harmonic way (as the wheel rolls). as im driving slow i hear that constant squeak coming and going. also, when i slow down (ie brake) i hear a loud squeal. its not the brakes because i just had them changed not too long ago. even if i dont step on the brake pedal, even if i just slow down from friction i hear the squealing. it goes away after about a minute. i just had it lubed and still does it. any ideas?
sd88supra is offline   Reply With Quote
