is it possible by any chance that the squeaky noise showed up AFTER you did your brakes? its possible either the wear indicators were not installed properly or the anti-squeal shims are in there funny and squeaking against the rotor.
This is gonna sound odd, but can you describe the squeak a little better? high or low pitched? does it seem to change tempo based on wheel movement (speed) or engine (RPM) Is there a grinding (like metal on metal being chewwed up)component to the sound? or is it more of just a nails on the chaulkboard squeak?
You mentioned it changed when you step on the brakes. Does the sound go from like a "squeak ...squeak... squeak" to a "SQUEEEEEEL" or some other pitch change?
not being there to hear it, this kind of information can help narrow it down.
____________
