Originally Posted by Supra2NR
i need everybody's attention on this one
Which Joel gave you.
i...what if i tell you guys that i got an idea , to replace traditional turbos.
one thats electric, no waiting for spooling since its always on. no need to tap oil return pans,
the only challenge is to come up with enough electricity from the 12 volt system.
Well that is all you described and for what you described, you got an answer.
If you later say "that is not what I meant you, idiot" you would be in the wrong because you never explained it enough to distinguish it from what Joel showed you.
It would be like me saying, "it has wheels and a motor" then you say, "a car" then I say, "no, a motorcycle, you idiot"
Based on what you described, you got a valid answer.
Leave the name calling out of threads as that is a rule here, whether it be written or not.
As far as Joel, he is a moderator of another forum and a great contributor on this one as well. He is a pretty good natured person as I have dealt with him and seen many many of his posts. I doubt he ever intended anything mean-spirited, and I don't know where you got off thinking so.
