shocks just resist the movement of the suspension, and give the spring a place to act, in the mk3 anyway. A strut is actually a structural piece of the suspension. It takes the place of the upper a arm and shock/spring. Which is why strut bars and camber plates are useless on supras. Camber plates are for whne you lower a front wheel drive car, it moves the struts out, so the camber isnt so far in. And stut tower braces stop the struts from moving closer and away from each other, which also doesnt happen on a supra, because it has shocks. Mk3 btw, not too sure if mk4 is struts or shocks
