so ok would the stock fuel pump deliver enough fuel so i wont run too lean and screw up my engine , i think i heard stock fuel pumps for the turbo and the n/a are the same, dunno tho 4got,
Actually, if you're really serious about doing some twin-ESC setup, hook them up to a relay, and then activate the relay using a WOT switch. Whether it really be at WOT or 1/2 throttle, that way you won't have boost at idle.
which relay?? wot?? whatta what what? jus a lil bit more specific please, like i said b4 im new to this
and its not an electric supercharger, why do peole think thats what im gonna do?
is it bcoz it jus had a sudden surge in the market? if you get those its only a 5% increase on your hps, not really worth it since it costs around 250
