Paul, did you do anything before they stopped working (dash lights that is), or have they ever worked for you? did they all suddenly stop working? Its silly I know but did you mess with the dimmer to see if anything happens?
Pulling the dash out isnt that hard really (I just did it 3 times in the last 2 days...sigh* but thats a different thread) you need to pull the climate/stereo bezel, the switch pod on the left side and then the beauty cover before you can get to all the dash screws. almost all the screws are the same size and type so getting em back in is simple.
If you've already checked the fuses and the dimmer, your probably gonna have to pull the dash out and see if anything is unplugged and to check your bulbs. if you do that, the only bulbs to concern yourself with are the ones with the green sockets, there are 5 of them. They are standard bulbs with little green condoms on them...now would be a good time to change the bulbs to the color of your chioce if you wanted to do that.
Let us know how it goes
____________
