Well first things first...
I suspect, though Im not sure, that your 22 code has nothing to do with your car not starting. The 22 code is most likely the sender is bad or even could be as simple as a bad connection at the sender. Check for corrosion first, then if no corrosion I would replace the sender. Worst case, its in the ECU...but cross that bridge only if you come to it.
as for you car not starting...do ya get anything? a Click? if not it could be the solenoid, or possibly the starter relay. there is also a master breaker that might need to be reset. If you get a clicking but no turn over, then the starter motor is probably bad, which I understand is a real pain to change.
Keep us updated
____________
