Before this i started my car maybe 5 times the last day i ran it and nothing happened, everything was normal. Come home and try to start it heres what happens-
I turn the key to ACC:
- the head unit/radio gets power
-clock comes on
-door light and sound come on
...everthing seemed normal.
I turn the key to ON:
- i hear some relays 'click' in the engine
-TEMS lights come on
-Engine check light is on
-airbag,parking brake are on and everything is on and working
Turn the key to START:
-nothing, just the radio and clock go out when key is in start position like they normally do. no clicks, no engine turn.
i checked the fuses and everthing in the kickpannel that deal with the ECU and found nothing.
if nobody has any suggestions i will call my local toyota dealership.
i dont see how code 22 (water Temp sensor signal) would have anything do do with it?
hope it's not the ECU
