Thread: Car troubles.
Old 03-21-2005, 04:42 AM   #11
robert lopez
Guest
Posts: n/a
Originally posted by Kyle@May 5 2004, 11:11 PM
I have an 1987 Supra Turbo, and the other day i was driving it. i was in second gear and my RPM's just droped, so i went to first gear and it just died. when i had an jeep wrangler and i used to go off roading it used to do the same when i got it all soaken wet. I've check all the fuses, checked the coil, even tried to put ether in the intake to see if it start and it wont. It will turn over like it normal does and it's not fast. It has pressure because it doesn't turn fast. i have no idea what it could be, it just doesn't wanna run. plz help thank you
Kyle
hey my 87 supra is doing the same thing. have you unpluged the battry? i heard that if the battry is unpluged for more then 15 mins. that all the coeds in the ecu will rest or something. my supra is auto, but when i get in the second gear and i floor it the rpms only go to like 4k then the car will go to 3rd gear. im not sure what the problem is but when i find out ill give you a better clue as to whats going on with your car. e-mail me at techiebob1666@msn.com
