I don't know how accurate this info is but there are several sites that have the same info.
http://www.geocities.com/motorcity/p...Injectors.html
You will have to make sure that if you do swap injectors that the plugs are the same or you will have to swap plugs to the new style. If the pins are the same you just have to unlock the pins from the old plug and insert in the new one. So much cleaner looking than cutting and spicing.
