Originally Posted by dcrusupra
Check spark plugs and wires, any oil in the spark plug gallery, check the AFM, check the connection to the AFM, clogged injectors, maybe timing problem, vacuum leak?
i think its ether a timming problem or a vacum leak. But will having no back pressure cause this? Also how does a car run off timming?
