Just one question....is it an AC motor? because if so it will not work. Some brushed ac motors will even run off of dc, But will not go very fast. About 10 times less than operating speed. Because your dc is only 12-15 volts. And an inverter cant handle running an electric motor for very long. Plus they are just inefficient. If you really want, I could wire up a board that would work off the TPS to modulate a speed control signal. Youd need a sperate electronic speed controller though
