Old 06-17-2006, 02:17 AM   #40
Isphius
Isphius's Avatar
Jet engines work kind of like that. They have a small electric or really small jet motor that spools up the larger motors so they can start. It wouldnt be hard to do that with a turbo. Youd actually pre pressurize the exhaust, And if thats what you were thinking of doing, Kudos. You would need a one way flapper valve kinda thing. Not hard to make. So exhaust gas doesnt come out when the pressure builds. Plus the motor would have to make more CFMs and pressure than the motor running at idle. You might be able to use parts off of a 2jz gte or a twin turbo rx7, cause they have valving like that for the sequential turbos.
