Originally Posted by damdog05
so i was wondering about the tires. should i let some air out so there is more rubber in contact with the road, or would that just cause more drag? maybe keep em filled up front and let some out of the back?
yeah if your running street tires you can drop the rears down to about 25 lbs. Any more than that is really counter-productive on street tires. Keep the fronts at full pressure.
you could go out and find yourself a set of mickeyT's cheater slicks. I think you can run those down to about 15lbs or air. They are essentially racing "slicks" with tread on em and DOT approved.
When bracket racing the most important things to do are cut good lights and stay consistant. Dont race the guy next to you...run your own race.
