2jzgte 2jzge
is there any difference in the casting of the blocks and heads of a 2jzgte and a 2jzge i know the compression is different and the valves and cams and rods and crank are different. i know the 2jzge runs a distributor and the 2jzgte runs coil over plugs. if the heads are the same is there a block off plate that covers up the hole for the distributor or whats the deal. somebody let me know what the difference is between castings of the block and head thanks alot zack bower
