Old 06-20-2006, 11:00 PM   #13
superpage1987
superpage1987 is on a distinguished road
Default psi
Well it will change from tire to tire sum run around 35 others 44psi. Your psi ratind is maked on the side wall. I would recommed tring to stay withing 7 or 8 pounbds of that, but try a few run at the recommended psi the try going up or down see if you can find where they run better for you. Just remeber every one drive a little different so try a few thing see what works best for you. O ya i run mind all the way to 5600 but it is an auto so it shift slow anyway.
superpage1987 is offline   Reply With Quote
